Inventor General
Member
micah.milliman
Message 1 of 10 (591 Views)
Factory Design Layering when Exporting to AutoCAD
591 Views, 9 Replies
03-27-2012 05:06 PM
Our company specializes in manufacturing engineering and layouts, and we are to the point where we are beginning to lean heavily on the 3D modeling of Inventor and the various product suites that we have on subscription.  However, in this process of switching over to 3D for all of our design work, we have noticed a bit of disconnect between the 3D world of Inventor (in particular Factory Design Suite) and the 2D world of AutoCAD.  What was so attractive about the Factory Design Suite was the ability to lay out an entire facility using provided factory assets along with the our designs coming out of Inventor.  We were also very excited about how the assets were also in 2D and how we could blow out our own "user assets" to be used in 2D.  We figured that this would streamline what we are already doing and elevate Factory Design to being an invaluable asset.  As we have gotten further into the Factory Design Package, we have noticed a few things that would really be helpful for what we are currently doing that would make the transition from 3D to 2D much MUCH easier:
1) The ability to assign 2D assets, upon creation, to a specified NCS (National CAD Standard) layer
2) The ability to assign NCS layers from within the an Inventor dwg
3) The ability to assign NCS layers from within an assembly file to specific parts and subassemblies
All of our clients need these files in usable CAD format, which makes it neccessary to go from Inventro to AutoCAD.  (We have found that just sending Invetor files, exported as AutoCAD dwg's, is messy, with no blocks, and roughly a billion tiny little lines... I may be exaggerating)  We are currently creating levels of detail in our Factory Design Assemblies that eventually act as our layers in CAD.  We are creating 1:1 drawings of our layouts in Inventor and doing a save as into AutoCAD dwg format for each level of detail (ex. a "fire protection" level of detail, an "electrical" level of detail, an "equipment" level of detail, etc.)  We then use these AutoCAD drawings as xrefs and assign layers then.  This works fine if your are only doing it once, but when going through the design process of updating and reviewing with clients, it becomes extremely tedious and takes a painful amount of time to continually refresh all of these levels of details and resave them into AutoCAD format, only to have to refresh them (the xrefs) once again in your AutoCAD model space.  If I were to be able to assign layers in Inventor, it would most definitely streamline this process.  Any thoughts or suggestions on how to improve our workflow would be appreciated along with any support or fixes for the items listed above.
Going from 2D to 3D in Factory Desing is amazing with the use of assets and the "Auto-place 3D Assets", but then returning to 2D, where quite a bit of work is still done, seams to be a bit lackluster.
Product Support
dave.anderson
Message 2 of 10 (554 Views)
Re: Factory Design Layering when Exporting to AutoCAD
04-04-2012 01:27 PM in reply to: micah.milliman
You have some very good feedback here. To ensure that it's seen by the product developers, you might want to copy/paste it in the Product Feedback page here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Dave Anderson
Premium Support Analyst – DLS Mechanical Design
If I have answered your question, please "Accept Solution" so others may benefit as well.
Mark_Flayler
Message 3 of 10 (540 Views)
04-04-2012 09:03 PM in reply to: micah.milliman
You really should check out 2013's workspace sync with AutoCAD.
http://blogs.rand.com/manufacturing/2012/03/factory-design-suite-2013-suite-enhancements.html
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
Member
adam.moore
Message 4 of 10 (509 Views)
04-18-2012 11:50 AM in reply to: micah.milliman
Our company has also recently ventured into the world of plant designs from inventor to autocad.  We have been playing with the 2013 version and like the new features but have the same problem.  How can you map objects in inventor so they can be on set layers when displayed in your 2d autocad file.  This seems to be the only hangup up we have so far.
Member
adam.moore
Message 5 of 10 (495 Views)
04-20-2012 06:55 AM in reply to: micah.milliman
Does anyone have any ideas or work around for this problem.
I tried editing the refernce file from within autocad and was succesful at putting the model on layers, but the next time you sync from inventor it overrides the layers and defaults to the 3d layers imbedded into Inventor somewhere.
I'm not a guru on modified coding, but would it be possible to remap those default layers to something new within the code.
Member
micah.milliman
Message 6 of 10 (475 Views)
04-23-2012 07:22 AM in reply to: adam.moore
Hey Adam,
We have been in discussions with some members of Autodesk, and the layering issues/desires mentioned in first post are currently in backlog and will be in a future release.  We are currently working in 2012 b/c we haven't had the time to migrate our Vault server yet.  From my understanding, 2013 plays better with AutoCAD, but you still loose layers.  For now though, our office has produced a bit of a work around that I think could help you.
If you set up your master assembly in Inventor to have levels of detail for all of the layers you are hoping to create, you can then create a standard Inventor dwg for each of these levels of detail.  These Inventor dwg's will then autoupdate once you make changes and reopen them.  Once you have these drawings set up, do a "File", "Save Copy As" and save them as an AutoCAD dwg and within the "Options" dialogue box, set the file version as AutoCAD 2010 Drawing and click "Next".  Then, within the "Exporting Options" set the "Data Scaling" as "Full Scale (1:1) - Model Space".  Click "Finish".  Once you have done this for all of the dwg's, you can then bring them all into your AutoCAD dwg and set the xrefs' layers.  When updating/refreshing these xref's then, you do not lose your layering.  It actually works pretty well if implementing Vault.  We have a separate CAD guy, so I just have to let him know that I have updated the dwg's and all he has to do is refresh from Vault and he still has all of his layering.  Hope this helps.
Distinguished Contributor
Light_Guy
Message 7 of 10 (450 Views)
06-01-2012 07:21 AM in reply to: micah.milliman
We are pushing to move into this same arena at my work, using the Factory Design Suite. This post if very timely as we are about to start test piloting and are developing our processes. I am currently using just plain Inventor to do compartment (name for rooms on ships) layouts and found this post trying to figure out how to get my layers set when I drop the layout to 2D for our production folks.
PLEASE Autodesk, we need a layer translator or something in Inventor to make this an extremely useful tool.
Paul Hamor
"Always good ships!"
Member
LyndenCopeland
Message 8 of 10 (417 Views)
06-04-2012 05:58 PM in reply to: Light_Guy
I am not confident that the Object oriented Inventor can make a good translation to Autocad, but I have a suggestion to at least get layers into the output.
  • If you go to the Styles Editor you can create a new style.  Go to Object Defaults and assign layers to each of the various Objects in Inventor; linear dimensions, visible lines, details, etc.  These layer names are to be exactly as you require in the output drawing.
  • Set you dimension standards in Inventor with the same name as you use in Autocad.  Make sure they are configured to be like your Autocad layers, for example, Standard (mm) would need to be millimeter, etc.
  • Export the style so you can bring it in for other drawings.
To output:
  •  go to Save Copy As and select the Options button.  Step through the options and select what you need for output.  There is a tab there that lets you assign Inventor linetypes to your Autocad linetypes.  You will also need to specify an Autocad template.
  • If you do this right there will be no Inventor layers in the output drawing.  As I recall dimensions come in as valid dimensions also.
Hope this helps or gets you going in a direction that you can make use of.
Light_Guy
Message 9 of 10 (406 Views)
06-05-2012 08:29 AM in reply to: LyndenCopeland
Thanks Lynden. Some of that will help but my biggest problem is that many of my objects are all the same linetype. They get separated in AutoCAD by color and lineweight, thus the different layers. Depending on who is dropping from the model, they made need pipes to be a heavy lineweight while electrical equipment is a thin lineweight to that their discipline objects stand out from the rest. Likewise the other disciplines would be doing the same with their equipment. Right now, we do not dimension or label in Inventor, it would all be done in AutoCAD after the drop. This is a new thing for us so we are trying to learn how everything works as we develop our in-house process. Getting items to their respective CAD Standards layers quickly is one of our biggest challenges we can see right now. If that process winds up taking so much time that we have negated the time saved by doing the modeling it takes us right back to where we started.
Right now, pretty much every line that comes over into the 2D drawing is on the Visible layer and we have to separate those out before we turn it over to  production and the customer.
Paul Hamor
Mark_Flayler
Message 10 of 10 (403 Views)
06-05-2012 08:49 AM in reply to: Light_Guy
It seems like ACADm might be a possible workaround to get you there and maybe run a dws file on the standards, but I can't seem to get the exporter to recognize I have ACADm on my machine...from the wikihelp:  A little help Autodesk?
If AutoCAD Mechanical is installed on your computer, you can set options to save the drawing in a format that uses AutoCAD Mechanical capabilities.
Part references are created according to the following rules:
  • You can specify whether to create the part references for all the parts in an assembly or just the first level parts and subassembly components. The name of each part reference is the file name for the component.
  • Layer groups are created for each part or component instance in the assembly. The geometry and annotations associated with the component are placed on the layers in the appropriate layer group.
  • Part references are not created for parts that are not visible in the Autodesk Inventor drawing.
  • If there are multiple base views in the Autodesk Inventor drawing, the first base view on the first sheet is used as the basis for parts list information.
Access:
Click Save or Save AsSave Copy As, and select an AutoCAD Mechanical file, and select AutoCAD Drawing (.dwg) as the file type. Click Options. In the DWG File Export Options dialog box, ensure Create AutoCAD Mechanical file is selected, and then click Next.
Top Level Assembly
Creates a parts list containing the top-level components in the assembly. The parts list does not show components in subassemblies.
Parts Only
Creates a parts list containing all parts in the assembly. The parts list does not show subassemblies, only the parts in the subassemblies.
Create Layer Groups
Creates a layer group for each component in the parts list. Check the box to create the layer groups. Clear the check box to omit the layer groups.
Select Available Fields From:
Selects the group of properties to display for selection. Click the arrow, and then select from the list.
Available Properties
Lists the properties available for part reference attributes in the AutoCAD drawing. To add a column, select a property in the list, and then click Add to move it to the Selected Properties box. To display other choices, use Select Available Fields From to select another group of properties.
Selected Properties
Lists the properties that appear as part reference attributes in the AutoCAD drawing. To remove an item from the list, highlight it, and then click Remove to move it to the Available Properties box.
NoteThere must be at least one property in the selected list.
Add
Adds the highlighted property in the Available Properties list to the Selected Properties list.
Remove
Removes the highlighted property from the Available Properties list.
Move Up
Moves the highlighted item in the Selected Properties list up in the box.
Move Down
Moves the highlighted item in the Selected Properties list down in the box.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
