Inventor General
Distinguished Contributor
luismestre
Message 1 of 4 (433 Views)
FORMAT TEXT NOTES
433 Views, 3 Replies
08-30-2008 03:09 AM
Hi all,
Today my question is related to text format.
Is possible to use the tab key to format the text or should we use the space bar key and align the text again by eyeball?
Regards
Luis Mestre
Luis Mestre
Oil&Gas 3D Designer & Subsea/Structural Draughtsman
"Autodesk Autocad/Inventor & 3D Studio Max"
Email: l.m.s.mestre@sapo.pt
Website: www.luismestre.110mb.com
*Dennis Jeffrey
Message 2 of 4 (433 Views)
Re: FORMAT TEXT NOTES
08-30-2008 06:41 AM in reply to: luismestre
See Attached IDW ( 2009)
The simplest way to format text in Inventor is to create a Word document so
that you can:
1. Use tabs
2. Use numbering of Items
3. Format your document any way you wish
Then copy and paste from Word into Inventor. WordPad also works.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:6020045@discussion.autodesk.com...
Hi all,
Regards
Luis Mestre
Valued Contributor
Message 3 of 4 (433 Views)
11-06-2008 11:34 AM in reply to: luismestre
I have copy and pasted as well as inserted into Inventor as an object. The object inserted with the link option works well, especially since you can open the text of the word file from inventor and make changes that update in Inventor. If you so not see the text in your drawing, go to the tree and turn visibility on the inserted word document using right click. But, note that strange things happen if you change the margins.
Steve
IV11 sp4
Message 4 of 4 (433 Views)
04-20-2010 06:03 AM in reply to: luismestre
Doesn't work for me. I want to do a Number list with indents and 2nd line indenting like Autocad and the attached file. Copy/Paste into a Text Box in Inventor stripped all of the indents and tabbing...
Am I missing something?
Is there another way to insert the text rather than into a text box?
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
