Hi everyone,
I'm using students version of Inventor Proffesional 2014 and i have a problem with FEM simulation.
After a while when simulation start i get a message that i don't have enought space on disk C.
Is it possible to change somehow output directory of FEM simulation ? And what is default location of FEM output file?
I think you should look at clearing space on your C: drive.
I assume you did not remove the download of the Inventor from your hard drive after installation.
In a sense - you probably have 2 extra copies of Inventor on your machine.
1. The compressed downloaded install files. (I would burn backup to disc or removable hard drive and the delete from C:
2. The extracted install files. I would delete these. (this is not the installed program - think of these as the equivalent of a DVD install disk in your optical drive, except instead, on your C: drive.
and of course, all the games and pictures you have downloaded.
This is not a solution, i didn't downloaded Inventor to partition C, i have removed the instalation files of Inventor after a instalation.
Drive C is my system partiton and i have there only system and basics programs like office.
I would like to know where can i change the default directory of FEM simulation from disk C to some other partition ?
I used NX Unigraphics before and there i could set my own path of FEM output files before i ran the simulation.
Are you using Projects (*.ipj) or are you using Vault?
Try to move your temp file location. Stress Analysis uses the temp file during solve.
The temp file location is specified in Inventor Tools > Application Options > Files tab.
Point it to a drive with enough free drive space.
