Inventor Forum
FEA: Is there Deformation/Yielding Analysis?
8 REPLIES 8
Message 1 of 9
khowe
1071 Views, 8 Replies
I'm designing a part made of thin aluminum, used for alignment. It will be bent in different directions to do this. Is there a way the FEA on Inventor can tell me if I'm deforming the sheet permanent (plastic), or elastically?
Kevin
8 REPLIES 8
Message 2 of 9
in reply to: khowe
Inventor Simulation only has linear static analisys. You need non-linear analisys to test things on the end of the stress/strain curve and for plasticity. Inventor FEA will tell you when you're there, but won't give you results beyond that point. There are a number of companies that sell these packages...Ansys & Algor are the only two that play nice with Inventor.
Message 3 of 9
khowe
in reply to: khowe
Thanks. At what point do I know I'm there? Where do I get that information?
Or do I just look where the safety factor is less than one?
Message 4 of 9
in reply to: khowe
that is the good question. I also want to know the same thing, at what point we can say that it is permanat deformation or temporary.
At present I am considering the deformation after yield point as permananent and before yield point as temporary the yiled point is already in the styles for some material but I am not sure it is the right way to do.
Any help on this topic would be really appreciated
Message 5 of 9
in reply to: khowe
You need to take a class or get a good book on the subject. This isn't simple stuff. Amazon has a number of books on the subject and your reseller may know something about the subject. Inventor does show deformation as it's one of the plot, but again, beyond the yeild point of the material, the results are invalid. As well you must know that your mesh is consistent.
Message 6 of 9
mofid_mahdi
Hi
Apparently, Inventor can handle linear elastic materials only. Therefore it is recommended to employ another FEM software such as ANSYS, ADINA and/or ABAQUS.
You may export the problem geometry to a format accepted by the other FEM software.
For instance, ANSYS workbench can give the required solution of plastic deformation.
I hope this will solve the problem
Tags (1)
Message 7 of 9
kacper.suchomski
in reply to: khowe
Inventor Nastran supports many types of analyses, including nonlinear analyses.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 8 of 9
johnsonshiue
in reply to: khowe
Hi! And Fusion Simulation (cloud-based) too.
Many thanks!
Software Test Engineer
Message 9 of 9
Cris-Ideas
in reply to: khowe
This is very simpel
If stress exceeds yield stress for the material deformation will be plastic.
So if in results  in any part of the model stress exceeds yield stress deformation in this region is expected to be plastic.
(this obviously depends on how close analysis represents real case.).
Cris.
Cris,
https://simply.engineering
