Inventor General
Valued Mentor
GSE_Dan_A
Message 1 of 2 (102 Views)
FEA Capable to simulate a PL on a pipe?
102 Views, 1 Replies
01-18-2013 08:17 AM
Hello all,
I am wondering if the FEA in Inventor 2013 is capable of simulating a pipe under a point load and at what point the pipe fails.  Its a simple 2in dia pipe supported by a vertical tube with a load of 'X' centered on the pipe.
Thanks in advance.
GSE Consultants Inc.
Windsor, ON. Canada
cwhetten
Message 2 of 2 (92 Views)
Re: FEA Capable to simulate a PL on a pipe?
01-18-2013 09:14 AM in reply to: GSE_Dan_A
Yes, it can do this.  But it depends on what you mean by failure.  Inventor will perform a linear analysis, so any result with stresses above the yield stress will be meaningless.  But if by failure you mean "exceeds the yield limit", then Inventor will be of use.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
