Inventor General
Talayoe
Message 1 of 4 (1,220 Views)
Extrude around a curved surface
1220 Views, 3 Replies
04-27-2012 10:00 AM
Hello all,
I have a cylinder that has for lack of a better word, a zig zaged slot milled into the outside of it thru to the bore. I am unsure how to go about drawing this so I can get it to extrude correctly around the part.
From other cad software history, I could draw it on a straight plane and tell it wrap around the part of whatever diameter. But, since I have not attempted this in Inventor I dont know if this exists.
Just for reference, this is a twist lock device. Turn the cylinder, advance a key the is inside the zig zag advancing or retracting the part that is inside the bore attached to said key.
TIA! :smileyhappy:
-Randy
Inventor 2014 PDS
Message 2 of 4 (1,204 Views)
Re: Extrude around a curved surface
04-27-2012 11:21 AM in reply to: Talayoe
Emboss - wrap to face in Inventor (but technically this doesn't result in the true geometry.
Sweep with guide surface.
Attach your file here.
You didn't state what version of Inventor you are using.  There is also the cylindrical cam generator in later versions.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Talayoe
Message 3 of 4 (1,189 Views)
04-27-2012 11:47 AM in reply to: JDMather
I have attached my file.
So, with this instance I was actually tinkering with the option in sweep, but couldnt find the right combination. As such I have deleted the attemped paths and kept the zig zag geom only...as well as a couple of planes I created in the process.
Thanks fo rthe help!
-Randy
Inventor 2014 PDS
Employee
GlennChun
Message 4 of 4 (1,127 Views)
04-30-2012 10:54 PM in reply to: Talayoe
Please try the following and let me know if this works for you.
1. Invoke the Emboss command. The zig zag geom is automatically selected as a Profile.
2. Enter a desired value in the Depth text box.
3. Press the Engrave from Face button.
4. Add a checkmark to the Wrap to Face option, and you will see the Face button appear.
5. Select the cylindrical face, and you will see a preview of the wrapped zig zag geom on the cylindrical face.
6. Press the OK button.
HTH,
Glenn
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
