I've been breaking my brain over this..
Somehow I can't extrude several shapes in my sketch. I can't see the "share sketch" option in sketch 1.
After extruding 3 things, there is no extrude part available anymore, even though sketch 2 could be set to "share sketch".
I really need help with the following:
- why can't I choose "share sketch" for sketch 1?
- why does the "share sketch" feature of sketch 2 not allow me more than 2 extrudes?
- I made 2 sketches so that when I would use extrude, I can select an extrude per sketch. However, even though I select sketch 1, when trying to extrude sketch 1, it allows me to select sketch 2 features as well. Why?
- I cannot slelect the the feature without the round circle with legs, only the whole thing or the round circle with legs (see pictures). Why?
I hope somebody will have the time and energy to help me out..
Thanks in advance!
Squawk
Solved by johnsonshiue. Go to Solution.
Thank you JD!
Works like a charm.
I see that I need to 're-program' my way of thinking when using Inventor..
Tip: When adding symmetry constraints once you have added the first (selected the line of symmetry) you only need to select the entities for symmetry (you do not need to keep picking the line of symmetry if you do not leave the command).
I like to make the line of symmetry a center line constuction line for obvious visual reference going forward (a month from now I might have forgotten what I did). (actually, these days I forget what I did yesterday)
Tip 2: Mirror command is another way of adding symmetry - but I seldom use it (in sketches) as Inventor sometimes gets confused with mirrored coincident endpoints. So in general, avoid using Mirror in sketches.
Thanks for the tips JD!
They make sense..
lol.. Yeah.. I know what you mean.. Especially the things you don't think about when doing them.. 😉
Tip #2 doesn't make sense, but that is just the way it is.
Ok.. 🙂
It makes sense to follow your tips.. both of them.
Tip 2 may not be logical, but I've read the exact same advise in your and other tutorials and help files I've read so far.
It seems to be something nobody (above my noob level) uses that option in sketch.
Hi Curtis,
Could you tell me how you created the arc in sketch 2 and 3 in the file you sent me?
(your file attached)
Thanks rdyson.
Yes, I see what he did now. Indeed dimension from the centre..
Funny, I've been at it now for a week and things I didn't see ealier, I now wonder about why I didn't see them. 🙂
