Inventor General
Active Contributor
Message 1 of 4 (303 Views)
Accepted Solution
Extrude all Projected Geometry automatically?
303 Views, 3 Replies
02-07-2013 10:36 AM
I have looked thru the forum and didn't see this question anywhere.  Many times I have to make mounting holes on large assemblies that have a lot of holes to project and extrude.
Is it possible for the Extrude command to pick all Projected Geometry automatically?  If it looked only specifically for only projected geometry?  It would save so much time instead of having to pick every single projected geometry hole to extrude.
Thanks!
*Expert Elite*
Curtis_Waguespack
Message 2 of 4 (300 Views)
Re: Extrude all Projected Geometry automatically?
02-07-2013 10:44 AM in reply to: VeronicaSmith5891
Hi VeronicaSmith5891,
Here is a simple iLogic rule that I use to do this:
http://inventortrenches.blogspot.com/2012/03/ilogic-to-select-all-of-closed-profiles.html
I just set any profiles that I don't want to extrude to use construction lines, so that Inventor won't pick them up.
Here's another good tip for this sort of thing:
http://inthemachine-autodesk.typepad.com/blog/2010/08/embrace-the-intersect.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
IS200
Message 3 of 4 (275 Views)
02-07-2013 02:27 PM in reply to: VeronicaSmith5891
We project in from the assembly, select all, change to construction lines and centre points, then run the hole tool.
This auto-selects all the centre points and voila! Done. If you need to control the size of the holes you can cross link parameters between the part and assembly.
Active Contributor
Message 4 of 4 (224 Views)
02-14-2013 09:35 AM in reply to: IS200
This worked perfect!  Thanks so much!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
