Inventor General
Member
Message 1 of 5 (493 Views)
Accepted Solution
Extrude/Revolve on a given angle around a cylindrical body
493 Views, 4 Replies
12-20-2012 08:17 AM
I am really struggling in trying to revolve around cylidrical body on a specified angle. I understand the degrees of rotation angle, but i am looking to revolve or extrude a certain shape for the length of the shaft.  Like trying to make a coil or a set of threads.
Can anyone help? I have tried to use sweep but sweep doesnt work with two sweep lines.
*Expert Elite*
sam_m
Message 2 of 5 (484 Views)
Re: Extrude/Revolve on a given angle around a cylindrical body
12-20-2012 08:37 AM in reply to: MBixler
If you are trying to create a rotation along a length for a coil or to cut a thread try looking at the "coil" command.
hope that helps, Sam
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
*Expert Elite*
LT.Rusty
Message 3 of 5 (483 Views)
12-20-2012 08:43 AM in reply to: MBixler
I've always found that the Coil feature works quite nicely for making, well, coils.
YMMV, though.  The button is above and to the right from the sweep feature.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / 2xRadeonHD 4870 in CrossfireX
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
Member
Message 4 of 5 (474 Views)
12-20-2012 08:56 AM in reply to: LT.Rusty
I do not seem to have that coil feature for whatever reason on my tabs?
*Expert Elite*
Message 5 of 5 (467 Views)
12-20-2012 09:27 AM in reply to: MBixler
You are in the wrong forum - you are running Inventor Fusion, not full-featured Autodesk Inventor.
You should be over here http://forums.autodesk.com/t5/Inventor-Fusion/bd-p/370
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
