Inventor General
Message 1 of 4 (995 Views)
Extrude Cut from 3D Sketch (or something like it)
995 Views, 3 Replies
01-09-2013 09:54 AM
I know my subject is somewhat mis-named, because I gather that you cannot really extrude from a 3D sketch, however I am looking for a way to accomplish what extruding a cut from a 3D sketch would accomplish.
The problem is this: I have a simple 2D sketch that I've projected onto a curved surface (imagine a square projected onto the outside of a hollow cylinder). Now that I have a 3D sketch on the surface of the cylinder, I want to use that sketch as a "cookie cutter" through one wall of the cylinder.
If I were to simply extrude the cut from the 2D sketch, the "cookie" is wider at the edges than at the center. I want the cut to be perpendicular to the projected 3D sketch at all points.
I've attached a simple example that illustrates my problem.
Can anyone help? Thank you in advance!
Message 2 of 4 (992 Views)
Re: Extrude Cut from 3D Sketch (or something like it)
01-09-2013 10:02 AM in reply to: tvernonbaker
Split and Thicken-Cut
Emboss might also be a solution.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 4 (986 Views)
01-09-2013 10:10 AM in reply to: JDMather
Thanks!
New Member
Message 4 of 4 (393 Views)
12-03-2013 12:57 PM in reply to: JDMather
I know this is old, but good god, you just saved me so much time.  We do a lot of odd shape and transition HVAC style ducting, this saves my life!
Thank you, thank you, thank you!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
