Inventor General
Message 1 of 3 (863 Views)
Extension Spring Component Generator
863 Views, 2 Replies
10-30-2012 10:53 AM
Can’t seem to get it to work. No calculations required, just a 3d model.
Want a spring od 18mm, wire dia 2mm, with 52 coils, with something like a full loop or half hook hook type.
The dimensions I have entered in don’t seem to work.
What is the secret here?
Mike K
Joburg, South Africa
Employee
Message 2 of 3 (841 Views)
Re: Extension Spring Component Generator
10-30-2012 11:09 PM in reply to: MikeKovacik4928
Hi Mike
Could you post your data here? Is there any error message in the extended window of design dialogue?
Without considering calculation results, I tried and got the result if the parameters were suitable.
Inventor Professional 2014
Jingyi Liu
Quality Assurance Team
Message 3 of 3 (811 Views)
10-31-2012 10:12 AM in reply to: MikeKovacik4928
Thanks Jingyi
I got it eventually, by using suitable parameters.
I notice that using design accelerator you cannot (or not that I could see anyway) draw the spring in its free position (ie fully closed)
I therefore also drew it in ipt using conventional methods
I did notice that I had to use a pitch of 2.01mm (slightly more than 2mm) to prevent self intersection of solid bodies.
Also I was able to draw the hook ends a bit better than they come out in design accelerator. Also,  In accelerator the hook ends always come out parallel to each other.
However I am not sure what the practical reason is for not having them parallel to each other (as I have drawn in spring 01 .ipt)
However all being said and done, I don't know how the springs are actually manufactured and what a manufacturer would need to know. I am assuming the tension spring would be fully closed ( ie as I have modelled it without the design accelerator in spring01.ipt) when it is not under  load.
I think I will speak to the spring manufacturer tomorrow to ask him a few of what his required parameters are
Mike
PS I can't add all my attachments - they are too big combined even when  I zip, Therefore I will only add one+ 2jpegs
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
