Inventor Forum
Extended part cost in the BOM
1 REPLY 1
Billduck
435 Views, 1 Reply
   The BOM tabulates the item "quantity", and  "cost center", the latter recorded with the part thru iProperties.
Is there a way to have Inventor multiply these together for an extended cost. I know I could manually enter the # but that will not change automatically, when the part count changes.
1 REPLY 1
Mark_Wigan
in reply to: Billduck
Wthout programming i think you will have to just do it in excel after you export your BOM.
You will likely have to do that bom as parts only, all levels.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
