Inventor General
Valued Contributor
Message 1 of 2 (196 Views)
Extended part cost in the BOM
196 Views, 1 Replies
11-09-2012 10:44 AM
   The BOM tabulates the item "quantity", and  "cost center", the latter recorded with the part thru iProperties.
Is there a way to have Inventor multiply these together for an extended cost. I know I could manually enter the # but that will not change automatically, when the part count changes.
*Expert Elite*
Mark_Wigan
Message 2 of 2 (158 Views)
Re: Extended part cost in the BOM
11-12-2012 05:12 AM in reply to: Billduck
Wthout programming i think you will have to just do it in excel after you export your BOM.
You will likely have to do that bom as parts only, all levels.
best regards,
- Mark
PDSU 2014 Windows 7, 64bit. (please consider Kudos or Tag as Solved if your issue is sorted)
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
