I just flipped the locations of my monitors for use with extended desktop. In the past I have used my Laptop to my right and my monitor on the left and used the stand alone monitor for Inventor. We moved our office and I switched the locations (I was hoping that it would keep put my dimension dialog on the inventor monitor, but it still on the laptop no matter where I move it) so that my laptop is on the left and monitor on the right and I use Inventor on the monitor (on the right).
It's worked well for about a week, but today I was editing an iAssembly and the dialog pops up briefly before disappearing. I thought I would use the Alt+Spacebar and Move trick like I did with my other boxes. However, this particular box will not come back to my screen. I do the Alt+Spacebar and select move and I get the 4 Direction Arrow just like with other dialog boxes that move, but it never reappears. Any suggestions for how I might get this resolved?
I've tried turning off extended desktop, didn't work.
I've tried moving inventor back to the left side (laptop side), didn't work.
thanks
Solved by mcgyvr. Go to Solution.
See response from Matt Smith (Autodesk)
Thanks, that seemed to do the trick.
From Matt: HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion12.0\System\Preferences\Dialog
Inventor 2010: HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion14.0\System\Preferences\Dialog
