Inventor General
JanTheDesigner
Message 1 of 31 (4,261 Views)
Exports from Autodesk Inventor to other file formats
4261 Views, 30 Replies
03-27-2012 07:52 AM
We're working on a project for a client that involves producing an industrial video for them. We have asked the client to provide us with views of the product and product components as flat, 2D vector image files.
They have provided us with .IAM files, but we also need the files in other formats. So far, the client has only been able to send us flat, raster JPEG images, with muddy, dark gray gradation backgrounds, and the highest resolution they've been able to produce is 96ppi -- this is not going to work.  We've asked if they can provide isometric views of the product components in any of the following file formats:
EPS
AI
CDR
CGM
CGZ
DWG
DXF
FMR
PLT
SVG
OR if they can save the view as an Iges file (IGS), or a Collada file (DAE), we might be able to work with that.
But they do not seem to understand what we are asking them for.  Does Inventor export to any of the above formats?  And if so, can we somehow get step-by-step instructions on how to perform these exports, so we can send our client the instructions to provide us with the file formats that we need?
For that matter, does anyone happen to know of any video production applications that can handle IAM files as input? Help would be greatly appreciated!
"I'm a graphic designer, not an engineer!"
Cadmanto
Message 2 of 31 (4,256 Views)
Re: Exports from Autodesk Inventor to other file formats
03-27-2012 08:24 AM in reply to: JanTheDesigner
Jan,
These are the formats that Inventor can export out to.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
JanTheDesigner
Message 3 of 31 (4,249 Views)
03-27-2012 08:34 AM in reply to: JanTheDesigner
Thank you!  I see that DWG is one of the formats.  It looks like these are export options from Inventor Pro.  What if my client only has Inventor Light?  Are the export options limited there?
Cadmanto
Message 4 of 31 (4,242 Views)
03-27-2012 08:50 AM in reply to: JanTheDesigner
I am not aware of an Inventor light.  There are different levels (i.e. standard and professional)
and with all of those the export options are the same.  I know there is Autocad light.  There is also Inventor Fusion
with these export options.
Best Regards,
Scott McFadden
*Pro
ampster
Message 5 of 31 (4,231 Views)
03-27-2012 09:01 AM in reply to: JanTheDesigner
if they provided you .iam files, then they have a full version of Inventor.
Inventor LT doesn't do assemblies...
And yes, it can do .igs (.iges) also
JDMather
Message 6 of 31 (4,230 Views)
03-27-2012 09:03 AM in reply to: JanTheDesigner
It sounds like this client needs Inventor Training.
The files can be saved to dwg, dxf or igs (and other types).
If they are sending you *.iam files without *.ipt files - they are clueless.
*.iam files are assembly files - only contain list of hyperlinks to part files (*.ipt).
You could do the conversion yourself with FREE Inventor Fusion http://labs.autodesk.com if they can't get the dwg to you, but you will need the ipt files that go with the iam file(s).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
JDMather
Message 7 of 31 (4,226 Views)
03-27-2012 09:05 AM in reply to: JanTheDesigner
Ask them to log in here and respond to this thread.
JanTheDesigner
Message 8 of 31 (4,222 Views)
03-27-2012 09:06 AM in reply to: JanTheDesigner
Cadmanto: Understood.
I guess by "nventor Light" I meant the non-Pro version.
Good to know the exports are available from both versions.  I may now have enough information to communicate to my client.  Still seems odd to me that they wouldn't have known to do this and found the export to DWG on their own. Is this export done while they're displaying a particular view or rendering?  Can I ask them to leave out the dark gray gradation background?
MANY THANKS!!
JDMather
Message 9 of 31 (4,214 Views)
03-27-2012 09:14 AM in reply to: JanTheDesigner
...  Still seems odd to me that they wouldn't have known to do this and found the export to DWG on their own.
I estimate that around 90% of users do not know how to use the product.
The export will be a 3D model without any background.
If you need 2D you will have to be more specific.
It will be important to know EXACTLY what version of Inventor they are using to give them step-by-step instructions.
Have them log in here.
JDMather
Message 10 of 31 (4,213 Views)
03-27-2012 09:15 AM in reply to: JanTheDesigner
Oops, I missed this in the original post.  This complicates things.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
