Inventor General
Member
g.lawson
Message 1 of 10 (2,236 Views)
Exporting to STL files
2236 Views, 9 Replies
06-06-2012 03:50 AM
When I export from Inventor professional to an STL file for 3D printing. Everything exports ok exept threads. I have a model with M10 and M4 threads which never show on the STL file. Is there an option I need to tick to make sure they convert?
Thanks for any help
Cheers
George
Cadmanto
Message 2 of 10 (2,231 Views)
Re: Exporting to STL files
06-06-2012 03:58 AM in reply to: g.lawson
George,
Welcome to the forum.
Are you creating the threads as real threads or as cosmetic?  If they are just cosmetic threads then they are for on screen appearance only. Kind of like textures and colors.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Member
g.lawson
Message 3 of 10 (2,220 Views)
06-06-2012 05:32 AM in reply to: g.lawson
Hi
many thanks for your help.
They are real threads for bolt holes.
Cheers
George
sam_m
Message 4 of 10 (2,221 Views)
06-06-2012 05:43 AM in reply to: g.lawson
i think, what he means is - how have you made these threads?
if it's with the hole/thread tool then all you see is a cosmetic thread in Inventor as a texture - if this is exported to a stl/stp/igs/etc it will only show a hole of the nominal diameter (depending the options set).
The only way to export a thread in a stl is to actually model it with a coil cutting the profile down the hole - is this what you have done?
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Member
g.lawson
Message 5 of 10 (2,214 Views)
06-06-2012 05:55 AM in reply to: sam_m
Hi
many thanks for your advice.
I put the threads in the hole using the thread tool. I will take your advice and try using a coil to cut the threads.
Cheers
George
JDMather
Message 6 of 10 (2,199 Views)
06-06-2012 09:06 AM in reply to: g.lawson
g.lawson wrote:
Hi
You should be using the Hole command for threaded holes, not the Thread command.
In any case you need to model the actual theads.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
jarr.strydom
Message 7 of 10 (2,083 Views)
09-25-2012 08:41 PM in reply to: g.lawson
Still a little new to the whole program, however I'm trying to 3D print an object and I'm struggling to figure out how to export it as a STL file. Any ideas how to?
sam_m
Message 8 of 10 (2,067 Views)
09-26-2012 12:58 AM in reply to: jarr.strydom
You need to do a "Save copy as" to get the full list of filetypes:
"I" logo at top left -> Save as -> Save Copy as
(or use Export -> CAD Format)
Then use the "save as type" drop-down and select STL :smileywink:
remember to check the export options (click the options button on the "save as" dialog) to check you are exporting in the same units as your design, otherwise your print may well come out surprisingly large or small...
New Member
connor
Message 9 of 10 (1,491 Views)
04-06-2013 07:06 PM in reply to: g.lawson
Hello!
I made a gear with an inner diameter of .8 inchs. The gear is an IPT and when i export it to an STL, its inner dimension changes to a little more then 2 inches. Why is this and how can i fix it?
JDMather
Message 10 of 10 (1,482 Views)
04-06-2013 09:12 PM in reply to: connor
As indicated in the previous responses in this thread -
post image of your stl Options.
and how are you verifying the size of the stl part?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
