Inventor General
*Luis Andueza
Message 1 of 3 (590 Views)
Exporting .idw files to .dwg
590 Views, 2 Replies
10-20-2004 09:52 AM
Hi, I have the following problem when I try to export an .idw file to .dwg I use the save copy as menu, and after I chose the .dwg extension file and when I click on save appears a dialog box that says: "Could not open the DWG template file. Please check the path and try again" I have tried with many options in the option menu of the .dwg extension file, but nothing happens. Thank you for your help. Luis
Distinguished Contributor
Message 2 of 3 (590 Views)
Re: Exporting .idw files to .dwg
10-20-2004 11:03 AM in reply to: *Luis Andueza
Do you have a template file specified in the options box? Mine will export without it but I believe that Inventor will then use the first template file it finds in the registry (last Acad product opened whether it be MDT or just Acad).
Do you have an AutoCAD product installed on the system?
*Luis Andueza
Message 3 of 3 (590 Views)
10-20-2004 11:09 AM in reply to: *Luis Andueza
I don`t have a file specified in the options box. Also I tried to browse for a template but I don't know what template I have to look for, or where. And I have installed Mechanical Desktop 2004 and AutoCAD 2005. "tahdesign" escribió en el mensaje news:671843.1098295457819.JavaMail.jive@jiveforum2.autodesk.com... > Do you have a template file specified in the options box? Mine will export without it but I believe that Inventor will then use the first template file it finds in the registry (last Acad product opened whether it be MDT or just Acad). > > Do you have an AutoCAD product installed on the system?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
