Inventor Forum
Exporting PART List to excel does not seem to be working.
4 REPLIES 4
WillieArolf
935 Views, 4 Replies
I am trying to export a PART List into excel. But, can not seem to be working.
1. Double click on the PART List to edit
2. Click on the "Export Button".
3. Type a name of file "Project PART List"
4. Click "SAVE". seems to be working as it allows you save.
Launch windows explorer and search for the file you have just save. (No item match your search)
Thanks & Regards,
Willie
Autodesk Inventor Professional 2019
Windows 7, 64-bit
4 REPLIES 4
MingweiGao
in reply to: WillieArolf
Hi Willie,
Did you specify/change the folder for the excel file? This excel should be located here if it was created.
Steven Gao
Sr. SQA Engineer
Paul-Mason
in reply to: MingweiGao
For some reason the export parts list to Excel dose not like, or can not cope, with a table name in that particular box just leave it blank and if wanted add the table name manually in excel.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
WillieArolf
Hi Mingwei Gao,
Sorry for the late reply as I was on holiday.
Yes, all of the files are in 1 project folder.
Thanks & Regards,
Willie
Windows 7, 64-bit
WillieArolf
in reply to: Paul-Mason
Hi Mason-Paul,
That is a good workaround. Thank you for that.
Thanks & Regards,
Willie
Windows 7, 64-bit
