If it is the one that you downloaded from my site
http://www.cbliss.com/inventor/iCode then I know how it is suppose to
work (cause I wrote it). Pick the tool from the menu. This will
present you with a dialog giving you options on how to save or to just
save one of the current window. In all cases, it should put the jpeg
file in the same directory as the Inventor file. If the Inventor file
has not been saved (as in it is a new document), it should tell you to
save the document first. It is also possible that it will just die and
do nothing if something goes wrong.
Gary Cross wrote:
>Under Tools pulldown I have an "Export To JPEG" command but it does not seem
>to create a file I can find on my computer.
>Anyone know how this tool works?
>Does it come with IV? I just loaded the freeware IV Autosave from M2T.com &
>thought maybe it came from that download.
>Gary Cross
>gcross@crossdesign.com
