Inventor Forum
Export to DXF issue
8 REPLIES 8
Message 1 of 9
jbelle7435
1742 Views, 8 Replies
Export to DXF issue
Program: Inventor 2012
Type: Sheet Metal Mode
1. Right click my Flat Pattern
2. Select "Export Face As"
I select the option and I do FOUR separate test(2000,2004,2007,2010)
 and save each on accodingly
part_2000.dxf
part_2004.dxf
part_2007.dxf
part_2010.dxf
when I drag each of them into "AutoCAD 2009 - English Version 2" I get this
Unknown value "AC1024" encountered in drawing version.
Invalid or incomplete DXF input -- drawing discarded.
I understand 2010 not able but the last 3 from before 2009. Am I missing something here??
Inventor 2012
8 REPLIES 8
Message 2 of 9
Hi
Dioes this happen with just one file, or andy sheet metal file that you save as a DXF?
Can you attach a DXF file that demonstrats this here?
Have you read this post, and or tried the suggestion of renaming and using the standard open method?
I hope this helps.
Curtis
Message 3 of 9
Attached are all DXF. It is a simple contour flage. if you need the .ipt let me know I will review that info you gave me though
" Have you read this post, and or tried the suggestion of renaming and using the standard open method?"
what post. I thought the thread under your name was the reference 🙂
Inventor 2012
Message 4 of 9
jbelle7435
in reply to: jbelle7435
just tried the
1.Autocad 2009-->File--open--Dxf and same error came up
2. I renamed 2007v to .dwg and tried opening and said "Drawing File is not Valid"
Inventor 2012
Message 5 of 9
Smiley Embarassed
Sorry for the confusion, I forgot the link, but here it is:
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Error-importing-dxf-file/m-p/3875229#M158...
I'll have a look at the attachments when I get a moment.
I hope this helps.
Curtis
Message 6 of 9
ok so from what it sounds
Code          Version
AC1027      AutoCAD 2013/2014
AC1024      AutoCAD 2010/2011/2012
AC1021      AutoCAD 2007/2008/2009
AC1018      AutoCAD 2004/2005/2006
AC1015      AutoCAD 2000/2000i/2002
AC1014      AutoCAD Release 14
AC1012      AutoCAD Release 13
I need Acad2010 minimum and beyond to fix this and see the .dxf?
Inventor 2012
Message 7 of 9
Hi     jbelle7435,
So when I opened your file named part_2000.dxf with Microsoft Notepad, I see AC1024  in the header information, which made me think that the file is not actually getting saved out as a 2000 version DXF.
So then a quick search turned up this thread:
http://forums.autodesk.com/t5/Autodesk-Inventor-General/Inventor-2012-export-dxf-versions/m-p/301009...
Which contains a link to this hotfix:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17027483&linkID=9242019
But it appears that this hotfix is inlcuded in ServicePack 1, which is actually included in ServicePack 2, so I would suggest that you install SP2 from this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19164683&linkID=9242019
I hope this helps.
Curtis
Message 8 of 9
thanks. will take a look soon at those.
Inventor 2012
Message 9 of 9
jbelle7435
the hotfix worked. Solution accepted.
Inventor 2012
