Inventor Forum
Export to DWG, mising "Part Number" text parameter
2 REPLIES 2
nannerdw
380 Views, 2 Replies
I'm using the "Part Number" parameter inside a block of text in my drawing, but when I export it to AutoCAD DXF 2010 format, the text in the exported file shows up as "<PART NUMBER>", instead of displaying the actual part number.
2 REPLIES 2
rhasell
in reply to: nannerdw
I had the same issue a while back.
Mine was via Leader text, t was also related to "Replace model References", it would only hapen after using that tool.
The solution was to discconnect the leader and then re-connect the leader, before exporting the file.  I never did find a solution to the problem, it just went away with version updates and patches.
Reg
2024.2
Please Accept as a solution / Kudos
nannerdw
in reply to: rhasell
The text was attached to a leader, and disconnecting / reconnecting the leader fixed the problem.  Thanks.
