Inventor General
Valued Contributor
Message 1 of 3 (155 Views)
Accepted Solution
Export to DWG, mising "Part Number" text parameter
155 Views, 2 Replies
12-03-2012 01:26 PM
I'm using the "Part Number" parameter inside a block of text in my drawing, but when I export it to AutoCAD DXF 2010 format, the text in the exported file shows up as "<PART NUMBER>", instead of displaying the actual part number.
-Using Autodesk Inventor Professional 2012
Valued Mentor
rhasell
Message 2 of 3 (147 Views)
Re: Export to DWG, mising "Part Number" text parameter
12-03-2012 03:49 PM in reply to: nannerdw
I had the same issue a while back.
Mine was via Leader text, t was also related to "Replace model References", it would only hapen after using that tool.
The solution was to discconnect the leader and then re-connect the leader, before exporting the file.  I never did find a solution to the problem, it just went away with version updates and patches.
Reg
Autodesk Product Design Suite Premium 2014 SP1-Update 2 Build 222
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please accept as a solution if it fixes your problem.
Valued Contributor
Message 3 of 3 (130 Views)
12-04-2012 03:56 AM in reply to: rhasell
The text was attached to a leader, and disconnecting / reconnecting the leader fixed the problem.  Thanks.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
