Inventor General
WernerBeek
Message 1 of 5 (301 Views)
Export text parameters of assembly into ipt (drawing)
301 Views, 4 Replies
10-05-2012 05:35 AM
Deal All,
I have created an assembly containing several parts. I want to export several  text parameters of the assembly and parts into the iproperties of the corresponding idw so that I can use them in a text block. Does anyone know how to makes this possible?
Thanking you in advance,
Werner
mrattray
Message 2 of 5 (292 Views)
Re: Export text parameters of assembly into ipt (drawing)
10-05-2012 05:53 AM in reply to: WernerBeek
What version? I'll assume 2013.
In a text note or in the title block?
If you need it in the titleblock you'll have to use an iLogic script to do this. (A very very simple one)
If you need it in a text note you can reference parameters directly in the text editor.
Mike (not Matt) Rattray
WernerBeek
Message 3 of 5 (289 Views)
10-05-2012 06:00 AM in reply to: mrattray
Dear Mike,
Thank you for your reply. I am working with inventor 2012.
This is exactly what I want, use the parameter into a text box. I do not know how to link the text parameter of an assembly or part with the ipt. Hope you can help me. With your solution you can not choose text paremeters.
mrattray
Message 4 of 5 (278 Views)
10-05-2012 06:24 AM in reply to: WernerBeek
I belive linking text parameters in a drawing file is a new feature of 2013.
Unless you want to upgrade, you'll have to use iLogic to filter through an iPoperty. Here's a snippet that will do so. You'll then simply insert the iProperty from the drawing into your text note.
iProperties.Value("Custom", "PropertyName") = Parameter("yourPart.ipt.yourParameter")
 Edit: This is a great example of why you should always include your version of Inventor with your original question.
WernerBeek
Message 5 of 5 (273 Views)
10-05-2012 06:32 AM in reply to: mrattray
Thanks a lot, that was the solution that I was looking for.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
