I would like to make a step file showing a representation/ postion in a design. I tried activating the postition before generating the step file and it opens in the 'master' position.
Thank you for your help.
Pete
IV 2011, all SP & Advan installed
Win 7 64 bit
Solved by japike. Go to Solution.
I haven't tried this, but could you use "Derive Assembly" using your positional representation to make a part file and then make a step file from that?
