Inventor Forum
Export a drawing in .PDF according to a rule
10 REPLIES 10
Message 1 of 11
amartin.r
993 Views, 10 Replies
I already posted in the Discussion Groups VAULT, but this place is perhaps better for my problem.
I want to create a .pdf according to a rule who is :
IF “iProperty Design State" = “Released” then ".idw is exported to .pdf in "C:/...
10 REPLIES 10
Message 2 of 11
Yijiang.Cai
in reply to: amartin.r
Please see the code lines below -
If iProperties.Value("Status", "Design State")=3 Then
    ThisDoc.Document.SaveAs(ThisDoc.FileName(False)& ".pdf", True)
'3 is "releaased" for design status, 2 is "pending" and 1 is "WorkInProgress"
' When using this code lines, the PDF file will be generated in the same location with IDW.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 3 of 11
amartin.r
in reply to: Yijiang.Cai
Thank you very much. It's good now.
I found this code, and I wish to use also, but It's not working. A tips ?
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_As_Black") = True
My rule
strFolder = "C:\...\" & ThisDoc.FileName(False)
If iProperties.Value("Status", "Design State")=3 Then ThisDoc.Document.SaveAs(strFolder & (".pdf") , True)
Then oOptions.Value("All_Color_AS_Black") = 1
Message 4 of 11
Hi amartin.r,
Here's a quick example that checks the Design State and then writes out a PDF if it's set to Released:
If iProperties.Value("Status", "Design State") <> 3 Then
MessageBox.Show("File is NOT Released, so no PDF was created.", "iLogic")
Return 'exit rule
Else
GoTo PDFOUT
'- - - - - write PDF - - - - -
PDFOUT:
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'get PDF target folder path
'example: C:\Temp\1234.idw
oFolder = oPath & "\PDF"  'returns C:\Temp\PDF\1234.pdf
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
MessageBox.Show("File Saved to: " & oDataMedium.FileName, "iLogic")
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Here's another example that looks to see if the Design State is not set to Released and then then gives the user a chance to release it:
    oQuestion = MessageBox.Show("This file is not released." _
    & vblf &  "Do you want to release it and create a PDF?", _
    "iLogic",MessageBoxButtons.YesNo)
    If oQuestion = vbNo then
    Return 'exit rule
    Else
    iProperties.Value("Status", "Design State") = 3
    GoTo PDFOUT
Else
GoTo PDFOUT
PDFOUT:
'Publish document
 I hope this helps.
Curtis
Message 5 of 11
Great, I did not hope so much.
Message 6 of 11
amartin.r
For existing files I created a macro button, and I do changes for to get document's name.
But following Windows configuration (show extension or not), the filename is "xxxx.idw.pdf" or "xxxx.pdf"
I tried to replace "DisplayName" by "FullFileName" but this doesn't work.
Sub PublishPDF()
'Get the PDF translator Add-In.
Dim PDFAddin As TranslatorAddIn
Set PDFAddin = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
'Create a NameValueMap object.
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'Create a DataMedium object.
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Check whether the translator has 'SaveCopyAs' options.
If PDFAddin.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
If TypeOf oDocument Is DrawingDocument Then
oOptions.Value("Sheet_Range") = kPrintAllSheets
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
'Set filename as original document filename.
Dim FileName As String
FileName = oDocument.DisplayName
'Set the destination to save files.
oDataMedium.FileName = "C:\...\" & FileName & ".pdf"
'Publish document.
Call PDFAddin.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Message 7 of 11
Yijiang.Cai
The value of document.displayname is related to the settings in folder options -> Hidden extension for known file type. If you turn this option on, the value should work fine. Please see the attached image too.
But when turning this option off, we need to add one code line in red backgroud to handle the file name -
FileName=Left(FileName, Len(FileName)-4)
River Cai
Autodesk, Inc.
Message 8 of 11
amartin.r
The problem, all user have different configuration (Show / Hidden).
I wish that the macro work with this 2 solutions, but if it's not possible, never mind !
Message 9 of 11
Yijiang.Cai
Please add the code lines below and have a try -
FileName = oDocument.FullFileName
Dim Temp() As String
Temp = Split(FileName, "\")
FileName = Left(Temp(UBound(Temp)), Len(Temp(UBound(Temp))) - 4)
River Cai
Autodesk, Inc.
Message 10 of 11
amartin.r
Great, I don't understand (Temp, Split, UBound), but it's working.
Message 11 of 11
Yijiang.Cai
These are used to handle the string to get the expected file name.
River Cai
Autodesk, Inc.
