Hi All,
I've been using 3D PDF Converter to convert my inventor models which have been saved by way of Export - CAD Format - Parasolid Binary Files. The default version is 25. You would think that this new version would be new and improved. However, it does not work. Anyone have similar results?
Solved by smallik. Go to Solution.
Hi smallik,
Thanks for the posting !
I don't know the version of your 3D PDF Converter and I suppose it is 3.4 version, if that is case, this version can only support Parasolid Binary or Text to v23, that's why it does not work. Refer to detail information via link http://wenku.baidu.com/view/8e7ccb9e51e79b8968022614.html
So 3D PDF Converter needs to update their release to support to convert Parasolid Binary or Text to v25.
For the workaround I think you can export your Inventor model to Parasolid Binary or Text to v23 then use 3D PDF Converter to convert.
Kevin,
Thanks for explaining the dynamics at work here. I'll bring this matter up with the folks at Tetra4D, makers of 3D PDF Converter, and see if they're interested in working with Parasolid Binary version 25.
Thanks again!
