Inventor Forum
Export Objects dialog box
0 REPLIES 0
Message 1 of 1
BeKirra
206 Views, 0 Replies
I am reading the topic of "Derived Component" and have a question for your guys.
This may be silly but I don't have much experiences in Inventor...
In the "Export Objects dialog box" in the help, I understand that I can mark objects for export.
But after marking them for export, how do I use these objects?
Can you give some explanations? A simple sample would be much appreciated.
Access:
Ribbon: Manage tab -> Author panel -> Export Objects
Thanks in advance.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 REPLIES 0
