Inventor Forum
Existing sketch to symbol
3 REPLIES 3
Myles1
1463 Views, 3 Replies
Is there a way to turn an existing sketch into a symbol, in an idw, so that it can be reused?
3 REPLIES 3
mpatchus
in reply to: Myles1
You can accomplish this as follows:
  1. Edit the sketch you wish to turn into a symbol.
  2. Select everything that you wish to be part of the symbol.
  3. RMB and select COPY
  4. Open your template file
  5. RMB on SKETCHED SYMBOLS in the browser and select DEFINE NEW SYMBOL
  6. Paste what you have copied into the sketch
  7. Save the new symbol with your desired name.
  8. Save your template file.
Seems tedious, but it has worked for us in the past.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
CCarreiras
in reply to: Myles1
Hi!
You can also turn it into a block and save it it a dwg file (library file).
Then you can use it everytime you want to place the symbol in the drawing.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
CCarreiras
in reply to: CCarreiras
Hi!
Forgot to mention before, but... using the tool "Import AutoCAD Block":
CCarreiras
