I often get a RSeClone Commander error when I attempt to move one or more parts or subasy' via browser from a nested subasy to the next asy or parent assembly. Anyone know why this happens & what I could do to prevent it?
Gary
If I delete the constraints in the lower level then & can move the component into the next higher asy. Looks like Inventor just doesn't like certain constraining. Is there a rule of thumb for this since many times I can promote fairly easily & the contraints are preserved.
Gary
These errors are not good as they are more of file corruption. The error message with RSE in it usually refers to a segmented database file with no real way to find out the cause. It could be a single part file or sub assembly. You can try to remove files out of your workspace directory. Reopen the top level assembly, skip links, and then repeat steps to see if error occurs. I wish I could give you something better than that.
Don
