I get this message everytime I make a 1/4" tube run:
"Adding this segment would make the previous segment violate the Minimum Segment rule once the fittings are populated"
I've already configured the tube style and when the route is run, it matches my configuration rules. I'm not sure why I get the message if it's following the rules. I have to go back into the route sketch and lengthen the segment that's giving me a "problem" to fix it. Also it's only the 1/4" tube runs that give me issues so far. Thanks in advance for your help.
Most likely has to do with the bend radius you have built into your tube style. Check the rules tab of your tube and pipe styles to see what your default radius is. If you know the bend can take place in a shorter radius change the bend radius. The reason that error existst is when there are two back to back bends that interfere with eachother because the distance inbetween is not sufficient for both bends to take place.
You didn't set a minimum length in your 1/4" tube style that's now throughing up this error.
I was actually thinking it did have something to do with the fittings. I don't use fittings in my tube style. Instead, I place fittings before I ever run any tubing. When I create a new tube style it gives the option of placing fittings when you run the tubing, but I leave it blank so as not to use them. Even though I've opted out of using the fittings within the tubing environment, I get a message that says the segment will be too short once the fittings are placed. Is there a way to tell the program I don't want to use the fittings? The only thing I could see to do was leave the box blank. I'm thinking if I could do this, it wouldn't give me the message or error. I attached some photos of my tube style.
