Inventor Forum
Error in Reading RSe Stream
6 REPLIES 6
2540 Views, 6 Replies
Error in Reading RSe Stream.
I tried to open up a part I had designed yesterday. Today it is giving me this error code and i'm not sure what it means or how to get my part back.
Help?
6 REPLIES 6
mrattray
Can you post the file here? A screenshot of the error? Have you tried using the Old Versions folder? Are you using Vault? What have you changed between then and now?
Mike (not Matt) Rattray
in reply to: mrattray
kwilson_design
You weren't by chance trying to open a 2015 Inventor file in 2014 were you? I can replicate that same error when I accidentally tried to open a test file in 2014 that was created in 2015.
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
mrattray
in reply to: kwilson_design
That should result in an error with something about kernel versions.
mrattray
That satisfies one of my requests (the least important one), what of the others?
I think the problem was the fact that my colleague opened it up in 2015, whereas I have yet to get the software update.
I opened up the old version and it was fine. Thank you.
