Inventor Forum
Error creating the relationships
3 REPLIES 3
a.prokop
253 Views, 3 Replies
Welcome.
I have a problem while creating relationships.
Not working properly function automatically create relationships.
Looks like a program error.
Nothing can be changed, even to accept the relationship.
Other options for creating realacji work properly.
Does anyone encountered a similar problem?
3 REPLIES 3
Cadmanto
in reply to: a.prokop
Are you talking about a problem constraining?  You can't get components in your assembly to constrain?  Is that the issue?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
I never use the Automatic.
Pretty simple to tell Inventor exactly what constraints you intend rather than Inventor trying to figure out your intentions.
a.prokop
Error probably caused install Update 2 for Inventor 2014 Service Pack 1.
I uninstalled the file and everything is back to normal.
I downloaded and installed again and now it is fine.
Except that the new file is different from the earlier size.
Probably autodesk introduced some changes.
