Inventor General
Valued Contributor
ChristianAlanJamesBerg
Message 1 of 9 (152 Views)
Error Loading Update 2 for SP 1
152 Views, 8 Replies
01-22-2014 10:48 AM
I was just getting around to installing Update 2 for Inventor 2014 Service Pack 1 which says it is cumulative and contains update 1 as well, but when I try to install it I get an error (see attached). I know that I have installed the service pack and have the correct version of Inventor. Does it require every hotfix to be applied as well? Any ideas?
blair
Message 2 of 9 (147 Views)
Re: Error Loading Update 2 for SP 1
01-22-2014 10:53 AM in reply to: ChristianAlanJamesBerg
Do the update 1 for SP1 first, then the update 2 for SP1.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Valued Contributor
Message 3 of 9 (118 Views)
01-22-2014 03:15 PM in reply to: blair
That was originally my thought but I don't even see a link to Update 1 in the Updates and Service Packs page. All that is listed for an update on SP1 is Update 2 which in its description says "this Update is cumulative and includes all changes contained in Update 1."
DarrenP
Message 4 of 9 (109 Views)
01-22-2014 04:40 PM in reply to: ChristianAlanJamesBerg
lets start with the obvious first
check and make sure SP 1 is installed
Valued Contributor
Message 5 of 9 (58 Views)
03-12-2014 02:34 PM in reply to: DarrenP
I am sure that the service pack 1 was installed and checked the build on Inventor. Update 2 and 1 were grouped together in a download so I am not sure if it expects me to have update 1 already and that is the reason it will not let me apply any of the updates... Is it required to install all the hotfixes before updating? Still have not found a solution and I would really like to be able to update my Inventor...
blair
Message 6 of 9 (51 Views)
03-12-2014 03:16 PM in reply to: ChristianAlanJamesBerg
Check front the Start>Control Panel>Programs and Features>View installed Updates. It will show if the SP1 has been installed. You need it for the Update 2.
Win7-64
Valued Contributor
Message 7 of 9 (48 Views)
03-12-2014 03:20 PM in reply to: blair
In the installed updates under autodesk inventor professional 2014 it lists "Autodesk Inventor Professional 2014 SP1" as being installed...
blair
Message 8 of 9 (40 Views)
03-12-2014 03:36 PM in reply to: ChristianAlanJamesBerg
Make sure you are installing the correct version, either 32 bit or 64 bit depending on your O/S and Inventor.
Win7-64
Valued Contributor
Message 9 of 9 (38 Views)
03-12-2014 03:43 PM in reply to: blair
It was the correct version. I finally have fixed it ... had to uninstall the service pack and reinstall it. Something must have been currupted the first time I installed it becuase I used the same file to reinstall the service pack again but now it recognizes that SP1 has been installed and will let me update it. Thanks for all the suggestions, still no clue what caused it to not recognize SP1 the first time but at least now it works.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
