hi
Inventor Software startup error the application was unable to start correctly(0x0000142). Appears.
help me
(Win 8.1 64bi and Inventor Professional 2014)
Solved by DarrenP. Go to Solution.
you need to install SP 1
Windows 8.1 is not officially supported by Autodesk
DarrenP
hi DarrenP
Thank you for your guidance.
The problem was solved.
you also need to do this after installing SP 1
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22446139&linkID=9242018
DarrenP
Does anybody know of a patch for the same problem for Inventor Professional 2012?
