Inventor General
karthur1
Message 21 of 24 (193 Views)
Re: Equation driven curve - unit error
11-29-2013 06:45 AM in reply to: 19112033
Max,
Can you show the function that you have plotted in message #20.
Kirk
Message 22 of 24 (175 Views)
11-29-2013 08:20 AM in reply to: karthur1
Sure, this is the equation:
"y=sqrt(2)*16.5/2/sqrt(PI)*sqrt(acos(1-2*x/50)-(sin(2*acos(1-2*x/50))/2))"
Plots like a charm.
Best regards,
Max
Employee
GlennChun
Message 23 of 24 (147 Views)
12-01-2013 11:47 PM in reply to: 19112033
Hi Max,
I've got a solution for you.
I entered the following equation:
multiplier * sqrt(acos(1 ul - 2 ul * x / length) / 1 rad - sin(2 rad * ( acos(1 ul - 2 ul * x / length) / 1 rad )) / 2 ul)
Change the first two user parameters (length and height), and the equation curve will update accordingly.
The attached IPT file can be opened in Inventor 2013 or later.
Hope this helps,
Glenn
Autodesk T-Splines Component Development
Message 24 of 24 (102 Views)
12-17-2013 10:39 AM in reply to: karthur1
Hi Glenn,
sorry for this late response, but thank you for your reply! Your solution works perfect for me, though I don't know why Inventor has to be so difficult in this manner, but who knows.
Thank you again for your help, I will mark this as a solution.
Best regards,
Max
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
