Good afternoon,
Can anyone help me to keep this line appears to apply Revolution to a stretch of "Ellipse".
Thank you very much!
Solved by innovatenate. Go to Solution.
....or go to the Shaded rather than Shaded with Edges visual style.
Good afternoon. Thank you both!
But there is a drawback in view of the model, this line remains in the file "IDW" and requires removing the "Visibility" manually in each case.
In the IDW remove the check mark (turn off) TANGENT FACES
Dear Paul Mason,
is not feasible for me to remove the case "tangent faces" as the need to show in this part and the rest.
Obviously I must move each line manually.
Also thank you very much!
Is it just me or does it seem odd that you see that line when the part is created with an ellipse but not with a simple radius?
Signed,
Curious in Houston.
Dear,
Exactly that is what catches my attention.
The reason that generates that "line" only when it is an ellipse....
In Inventor 2014, There are new Boundary Patch options you may use to generate this geometry without the tangent edge.
The result should be a smooth face with no edge.
Hope this helps.
Dear Nathan, good morning.
Thank you very much for your reply, both here and in the support case.
