Inventor General
Valued Contributor
Message 1 of 10 (316 Views)
'End if must be preceded by a matching if'
316 Views, 9 Replies
11-23-2012 12:41 AM
Iv attached a picture to show the error & my rule text. I have created the Parameters etc. & the statement includes if & end if. Cheers,Capture.PNG
Valued Contributor
Message 2 of 10 (307 Views)
Re: 'End if must be preceded by a matching if'
11-23-2012 01:33 AM in reply to: shmartin89
If Parameter("HEIGHT")=152.4
Parameter("UC_PROFILE")="152.4"
EndIf
If you are finding usnderstanding ilogic difficult, have a go at the online tutorials.
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2011
Windows 7 Enterprise, 64-bit
Valued Contributor
Message 3 of 10 (296 Views)
11-23-2012 03:48 AM in reply to: waynehelley
** Use "End IF', not "ENDIF"
Pasting into IE erased the space.
Wayne Helley
Valued Contributor
Message 4 of 10 (289 Views)
11-23-2012 04:58 AM in reply to: waynehelley
Cheers,
My text in the 'UC_designation' Parameter contains 'x's. E.g - 152.x152x23
Inventor recognises this as an equation, therefor the rule doesnt work. Is there any way around this without replacing the 'x's?
Valued Contributor
Message 5 of 10 (285 Views)
11-23-2012 05:09 AM in reply to: shmartin89
when you created the "UC_PROFILE" Parameter, did you create it as a text parameter?
If not, in the parameters dialogue, use the drop down in the bottom left which by default says "Add Numeric". Select "Add Text" instead.
Wayne Helley
Valued Contributor
Message 6 of 10 (266 Views)
11-23-2012 07:40 AM in reply to: waynehelley
Cheers Wayne.
This is the first time iv started using Rules. If you havent already guessed!
Sandy
Valued Contributor
Message 7 of 10 (262 Views)
11-23-2012 08:17 AM in reply to: shmartin89
Do you know if there is a way in which rules can be run automatically? E.g Everytime the part is updated or saved rather then having to press iTrigger
Cheers,
Valued Contributor
Message 8 of 10 (260 Views)
11-23-2012 08:24 AM in reply to: shmartin89
NVM. Iv added the rule into event triggers.
Valued Contributor
Message 9 of 10 (204 Views)
11-26-2012 12:20 AM in reply to: shmartin89
I'm not that knowledgeable about triggers I'm afraid, as I have only really been creating rules which I need to run on command, but have a look at this...
http://inventortrenches.blogspot.co.uk/2012/01/creating-basic-ilogic-rule-with-event.html
Wayne Helley
Valued Contributor
Message 10 of 10 (202 Views)
11-26-2012 12:23 AM in reply to: waynehelley
I just realised NVM stands for nevermind so mevermind my last post also!
Wayne Helley
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
