Inventor General
Active Member
girardeng
Message 1 of 3 (1,064 Views)
Empty Content Library
1064 Views, 2 Replies
02-08-2011 11:52 AM
Hello all,
I have successfully installed Inventor 2011, but it seems that all the Inventor Desktop Content libraries are blank.
I have looked in:
C:\ProgramData\Autodesk\Inventor 2011\Content Center\Libraries\
C:\Users\davorb\Documents\Inventor\Content Center Files\R2011
Also, the install is from a deployment (in case that matters)
but these folders are blank.
What am I doing wrong?
Thank you in advance,
Davor
**Master
BMiller63
Message 2 of 3 (1,059 Views)
Re: Empty Content Library
02-08-2011 12:04 PM in reply to: girardeng
go to Tools tab > Application Options > Content Center tab and look at the path listed there.
does that match those you listed?
Are you installing the Desktop CC file of the ADMS version?
What OS is this on?
Have you checked your Project file to ensure it is configured to use the libraries?
Also are you just trying to get them on the machine, or are you wanting to fix the deployment image for future.
Active Member
girardeng
Message 3 of 3 (1,056 Views)
02-08-2011 12:14 PM in reply to: BMiller63
Thanks for replying.
I realized that it was not enough to create the deployment and install. I had to then run setup from DVD one and manually select to install the content center on my computer.
Now, I can go back, and modify the deployment to include these from the C: drive.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
