Inventor Forum
Emboss in assembly
9 REPLIES 9
Message 1 of 10
rpenumatcha
2899 Views, 9 Replies
Emboss in assembly
Is there a way I can use the emboss feature in an assembly?
We typically laser mark during final assembly and would like to show that as a step in the assembly instructions.
I typically create a sketch with the text and extrude(cut) in the assembly.
It works fine for flat surfaces, but cannot do it for other surfaces.
The one way I can think of doing it would be creating ipart with text and using it in the assembly.
I would rather not do it this way.  Is there any other way to accomplish this with out altering the components (.ipt)?
9 REPLIES 9
Message 2 of 10
RobJV
in reply to: rpenumatcha
Without fully understanding the problem, have you tried derived parts?
Message 3 of 10
rpenumatcha
I know I can use derived parts, but want to avoid doing it.  I do not want to create any new parts.
Message 4 of 10
Unfortunately this is not supported currently. However there's a wishlist logged for this functionality #1458661.
Stanislav
Message 5 of 10
mrattray
I create a sketch in the flat pattern (I'm assuming sheetmetal) that I use for the actual laser programming, and in the drawing I use the retrieve model sketches command to show the etched lines.
Mike (not Matt) Rattray
Message 6 of 10
mercerc
            Although the emboss command is not available in the assembly features you can create a sketch in the assembly and place text in the sketch. Then you can extrude the text with a cut option. Not as many options as the emboss command but it will do what you want possibility.
Charlie M
Inventor Product Support Specialist
Message 7 of 10
MadcapPomposity
in reply to: mercerc
I hadn't thought of using the Cut command on text, but I just tried it and it worked perfectly! You obviously can't get raised letters with Cut, but it engraves just as well as the Emboss command does.
Using:
Inventor 2013
AutoCAD 2013
Message 8 of 10
rpenumatcha
Thank you.
Raju Penumatcha
Sr. Mechanical Engineer
raju.penumatcha@occfiber.com
[Description: OCC-Email-Sig-Logo]
1700 Capital Avenue, Suite 150
Plano, TX 75075
+1-972-509-1500 ext:108
Fax: +1-972-509-9009
occfiber.com
Connect with us...
Facebook | Twitter | LinkedIn
Message 9 of 10
In assembly i can not able to sketch without using create option,
Message 10 of 10
@elangovanhari199920
It would have been best to start a new discussion thread and Attach your assembly here (only one part needed - can be a dummy part).
