Inventor General
Active Member
Message 1 of 8 (403 Views)
Emboss in assembly
403 Views, 7 Replies
09-20-2012 03:15 PM
Is there a way I can use the emboss feature in an assembly?
We typically laser mark during final assembly and would like to show that as a step in the assembly instructions.
I typically create a sketch with the text and extrude(cut) in the assembly.
It works fine for flat surfaces, but cannot do it for other surfaces.
The one way I can think of doing it would be creating ipart with text and using it in the assembly.
I would rather not do it this way.  Is there any other way to accomplish this with out altering the components (.ipt)?
Message 2 of 8 (396 Views)
Re: Emboss in assembly
09-20-2012 03:44 PM in reply to: raju
Without fully understanding the problem, have you tried derived parts?
Active Member
Message 3 of 8 (359 Views)
09-22-2012 06:58 PM in reply to: raju
I know I can use derived parts, but want to avoid doing it.  I do not want to create any new parts.
Employee
stanislav.sedlak
Message 4 of 8 (328 Views)
09-24-2012 03:34 AM in reply to: raju
Unfortunately this is not supported currently. However there's a wishlist logged for this functionality #1458661.
Stanislav
*Expert Elite*
mrattray
Message 5 of 8 (321 Views)
09-24-2012 04:59 AM in reply to: raju
I create a sketch in the flat pattern (I'm assuming sheetmetal) that I use for the actual laser programming, and in the drawing I use the retrieve model sketches command to show the etched lines.
Mike (not Matt) Rattray
Product Support
Message 6 of 8 (311 Views)
09-24-2012 07:41 AM in reply to: raju
            Although the emboss command is not available in the assembly features you can create a sketch in the assembly and place text in the sketch. Then you can extrude the text with a cut option. Not as many options as the emboss command but it will do what you want possibility.
Active Member
MadcapPomposity
Message 7 of 8 (170 Views)
09-25-2013 08:01 AM in reply to: mercerc
I hadn't thought of using the Cut command on text, but I just tried it and it worked perfectly! You obviously can't get raised letters with Cut, but it engraves just as well as the Emboss command does.
Using:
Inventor 2013
AutoCAD 2013
Active Member
Message 8 of 8 (162 Views)
09-25-2013 08:39 AM in reply to: mercerc
Thank you.
Raju Penumatcha
Sr. Mechanical Engineer
raju.penumatcha@occfiber.com
[Description: OCC-Email-Sig-Logo]
1700 Capital Avenue, Suite 150
Plano, TX 75075
+1-972-509-1500 ext:108
Fax: +1-972-509-9009
occfiber.com
Connect with us...
Facebook | Twitter | LinkedIn
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
