In a part, I create a sketch, add annotation Type in the file name. Then create an Emboss feature using this sketch.
How can I add the file name property to the text. I want the the emboss to update to new file name if I rename the file.
Solved by Curtis_Waguespack. Go to Solution.
Hi CAD-One,
Mark Randa wrote some iLogic to do this (http://opendesignproject.org/).
I'm having some trouble getting his link to work, but I've attached an example file using his code, as well as a link to a video of it being set up: http://youtu.be/Y5a8IYyxFLo
In the example, you can change the part number iProperty and then save the file to run the ilogic rule. The attached file was created in Inventor 2010, in case some one with an older version is interested also.
Also, I'd look for this to be do-able "out of the box" in a future release of Inventor.
I hope this helps.
Curtis
Great help. Thanks
I was able to get this to work on an ipart that is vaulted. What isn't working for me is running the rule so the appropriate text is visible depending on which instance of the ipart is placed into an assembly. I would think that there should be some way to make the rule run when each of the ifactory parts are generated?
Marty Watts
Becker/SMC
Inventor 2012
Hi Doug_DuPont,
Starting with Inventor 2013 you can create a user parameter and then use that parameter in a sketch text field.
So the steps would be something like this:
> OR <
Create some iLogic code to:
I hope this helps.
Curtis
I also want to do something similar. I want to emboss part number on to the beam assembly. I have created parameter but how to link that to part number?
