I posted a avi on 9/01/03 with subject TEXT AND EMBOSS to IVCF that might help. Try to
select the text, not the bounding box.
Also I work with Application options>>Sketch >> Automatic reference edges for new sketch
turned off and Autoproject edges during curve creation on. This makes it so generally the
only selectable thing is the text. 8^)
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Chris Breidenbaugh" wrote in message
news:59501548457F00E58F5A013A167F4ED1@in.WebX.maYIadrTaRb...
> Yes this is IV 7 SP1. But it still is not functioning. I did get the
> text to look like outline text, but still no Engrave.
> Quinn Zander wrote:
> > This is one of Sean's most favorite aspects of IV.... its near useless
> > selection capabilities.
> > Basically, go in and select everything including the background then
> > shift-select (remove) the background.
> > Make sure you hold your tounge just right but try not to drool on the
> > keyboard.
> > QBZ
> > news:8B636E077D5C24DFF21009CCDA76014C@in.WebX.maYIadrTaRb...
> >>Having real difficulty getting a flat faced engraved with text.
> >>I have an existing part with IN/OUT water ports. I am trying to
> > engrave
> >>the ports with the appropriate text.
> >>I create a new sketch on the face. I then use the Create Text button
> > to
> >>create "OUT". I then dimensioned the box to the correct location.
> > Then
> >>select Finish Sketch. From Part Features, I select the Emboss Button.
> >>Here's where I run into trouble. I cannot select just the text box.
> > IV
> >>wants to select the entire face. When I did finish the engrave, the
> >>entire face was cut but the engrave depth (.1), leaving just the
> > inside
> >>diameter of the letter "O".
> >>Can anyone tell by this flimsy excuse for an explanation as what I'm
> >>doing wrong?
> >>Chris
