First off..Noob question... How do you embed (not link) an excel spread sheet into my sheet metal template. The excel file is simple, 2 rows listing the A1=gauge and B1= decimal equivalent.
What I want to do with this is to get the gauge to show up in the iProperties description along with length and width of part. The thing is I need colum A to show up in the iProperties (12GA) but colum B to be used for the sheet metal default thicness.
I keep getting this errorwhen I run my code.....
Error in rule: Gauge, in document: Part1
GoExcel: 3rd Party worksheet not found: "3rd Party:Embedding 1", Sheet: "Sheet1"
Code so far..
i = GoExcel.FindRow("3rd Party:Embedding 1", "Sheet1", "Gauge", "<=", iProperties.Value("Custom", "Gauge")) MultiValue.List("Thickness") = GoExcel.CellValues("3rd Party:Embedding 1", "Sheet1", "B2", "B35")
So I need help with both the embedding and code.
Solved by Breeze104. Go to Solution.
Design Data is the place your styles are saved if you project points to one but you have your applications options set to another this could be why.
Look at pics may help.
I thought that is what you were talking about and yes they are the same. I only have one main project and so all setting are according to it and I only have 1 ver of Inventor installed...2013
OK try this instead of saveas do a save copy as it is differnt But if they are in your styles it should show up. But I also have not load 2013 yet there are to many issues so I will wait till 2014 I hope they work out all the bugs by then. But I will not hold my breath LOL.
I have it loaded at the main office but I have not set up anything with it.
Ok I will try after lunch...Boss is cooking smoked brisket..Yummmmmm
One of the guys is retiring...I will eat an extra piece just for you...LOL
Here's one for you.....
I closed out of the file I was in...I checked the locations you wanted me to check...Reopened a new sheet metal part....and are you ready for this......
Now I have doubles of almost everything I created..How is that for bizarre....LOL
And it won't let me delete the styles I don't want..
LOL now you see why I did not load 2013...........
Do you remember when autocad was cursed by the odd number release well I think Inventor caught the bug....
I was having so much trougle with 2012 that I figured 2013 couldn't be to much worse...LOL
My first job I was using ACAD 13...So I din't know any different...LOL
What button are you talking about???
"how to you save back to template did you use the make template button?"
Well I can't remember 2013 but under the saveas if you wait another window expands and there is more options. But I don't use the template button the supplied I use save copy as not saveas
Here pic
Oh i see how you are helped you out and did not give me the solved wow really
Just kidding have fun with it
I did....
Back when you posted the code...on Page 5.... AND.... I gave Kudos on almost all your replies that helped. You must have a dozen + Kudos by now....
THANKS FOR ALL YOUR HELP!!!
Yeah i seen all them but I only giving you a hard time ..
But really don't care just want give you a hard time
Well after reboot I still have all of the styles...even the ones I didn't want and can't seem to get rid of......LOL
Did 2013 come with a Style Libary Manager I can't remember. it will be under the programs of your start button > inventor 2013 > tools
