Hello everyone..
I am designing a product using Autodesk inventor professional 2013.. I have a problem in setting the design of the part for the elastic element since i cannot mimic the behavior of the actual part. I have tried disecting the part into pieces and assembled it but still i cannot get a precise result.
Is there a way that we can make an elastic part with the actual elastic property in an assembly??
Kindly advise..
cats_eye
I suggest you try over at the Inventor forum
http://forums.autodesk.com/t5/Inventor/ct-p/70
Mark
By making a adaptive parameter (for example changing the radius of an arc) you can make a part "flex".
Can you attach your assembly here?
