Inventor General
Message 11 of 17 (200 Views)
Re: Edits are not allowed on this file
02-01-2013 01:19 PM in reply to: sbixler
I decided to delete the red inventor files in the libraries folder.  I deleted one and tried  it.  Still got he error.  Then I went back and deleted the other.  The errors went away.  I placed a part and saved the file.  It worked fine.  Do I need to add the library path back in?   I figure it's there for a reason and I'll find out the hard way.  I don't want to do mare damage.
*Expert Elite*
blair
Message 12 of 17 (196 Views)
02-01-2013 01:35 PM in reply to: killbox
No you don't need a library path. The reason for Libraries is to make the parts read-only. If you are working on a project and design a number of parts for that project. Another project comes along and you realize that you can use some of the parts from the first project, it would then be wise to add the folder/directory in which the first project parts reside as a directory. This still allows you to use the parts but not accidentally edit the parts.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Message 13 of 17 (193 Views)
02-01-2013 01:47 PM in reply to: blair
I just went to place a part and got the attached message.  What do I do with this?  This may have been the part that got things messed up before.  Other parts don't ask for the location.  The part is in the correct folder.  What is a proxy file?
*Expert Elite*
blair
Message 14 of 17 (188 Views)
02-01-2013 01:59 PM in reply to: killbox
Is this file in the same directory that is your work directory?
Haven't delt with DWG Mechanical drawings in so long I forget all the details.
Win7-64
Message 15 of 17 (184 Views)
02-01-2013 02:11 PM in reply to: blair
Yes, I downloaded it from a 3D parts site and added it to the work directory.  It's a servo motor I would like to use in the model.  They didn't have the correct format, but I have been told that Inventor can deal with lots of formats.  Maybe I'll go back and get the Solidworks format and see what that does.
Message 16 of 17 (180 Views)
02-01-2013 02:22 PM in reply to: killbox
The Solidworks version works fine.  So It may be a compatibility issue.
*Expert Elite*
blair
Message 17 of 17 (171 Views)
02-01-2013 02:33 PM in reply to: killbox
You might need to open this part in Inventor first, which do the conversion and save, rather than trying to place it in a assembly first.
Win7-64
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
