I'm using Inventor 2011.
Is it possible to edit text formatting (e.g. font, font size, alignment) on mulitple text boxes, rather than having to right click each and click Edit Text? Ctrl+right click doesn't bring the option up to edit text.
Bill
Solved by jletcher. Go to Solution.
What text style is it on? All you have to do is edit the style it will change them all.
If it is set on a style that you cannot change because it is link to other text you wish not to change then you would have to set a new style up and change the style for all you want changed but you will not have to edit every one and that is easy but takes time.
