Inventor Forum
Edit part iproperties from drawing using VBA maco
0 REPLIES 0
Message 1 of 1
pball
690 Views, 0 Replies
Could anyone help me with this. I found a macro which can edit the drawings iproperties, so I'm guessing it'd only be a matter of pointing the macro at the part instead of the drawing. Thanks
Function Fill_In_Checked_By(ByVal name, ByVal dt) As Boolean
' Get the active document.
Dim invDoc As Document
Set invDoc = ThisApplication.ActiveDocument
' Get the part number property.
Dim invPartNumberProperty As property
Set invPartNumberProperty = invDoc.PropertySets.Item("Design Tracking Properties").Item("Checked By")
invPartNumberProperty.Value = name
Set invPartNumberProperty = invDoc.PropertySets.Item("Design Tracking Properties").Item("Date Checked")
invPartNumberProperty.Value = dt
invDoc.Update
End Function
Tags (3)
0 REPLIES 0
