Im working on a plastic enclosure, I needed to make a hole for a connector but this hole would cut into both the top and bottom of the enclosure. Normally when I edit parts in an assembly I just double click them, they become transparent and I can do all my edits. Since I need to make a hole that cuts into both parts, I just went to the 3D Model tab started a new sketch and extruded out the cut. However doing it this way does not reflect the changes when the parts are opened on their own. Is there a way to have these changes tricle down to the part files?
thank you
Alan
Solved by SBix26. Go to Solution.
Unfortunatly, Assembly Features only reside within the assembly. You will need to open each part and make the edits within the part enviroment to appear in part drawings.
Edit the first part and create the hole in it, then open the second part, create your sketch and project the geometry of the hole onto the second part. By projecting the geometry, the second will be adaptive to the first, so any hole location change will affect the second part as long as "adaptivity" is still maintained.
You don't mention what version you're using (please always do that!), but this would have been an ideal application for mulit-body solids from 2010 onwards. All the editing and projecting done in one file...
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
😞 its what I was afraid of. Bummer, I have been doing it as you describe, was hoping editing multiple parts at a time would work.
Sam, I'm using Professional 2013. Just moved over from solidworks a couple months ago. The reason I'm not using multibody is because I am referencing a lot of the cuts from the actual PCB model that will be inside the enclosure. My workflow at the moment is:
Make a rough model of the top and bottom.
Assemble with the PCB inside.
Project the outlines of buttons, connectors, etc.
Cut the necessary slots.
Add lip/groove or snap depending on what im working on
Add all the necessary bosses, ribs, etc.
Add draft to everything
And Done 🙂
What do you think?
I have been having some trouble selecting faces to project. Say I make a sketch on one of the outer walls of an enclosure and there's a connector behind it. If I select Project Geometry its imposible to select the connector behind it because its not visible. I thought by right clicking and choosing "select other" it would allow me to do it but thats not the case either. What I have been doing so far is making a sketch on a surface of the connector and using the "slice graphics" to be able to project the connectors face to the sketch. Then I can project that sketch wherever I need it. Is there an option I have turned off that is not allowing me to select things behind where im sketching?
thanks for all your help
Alan
I'd still use multi-body solids. Just start by deriving in the PCB as surfaces, then model your enclosure around it.
Sam B
When you say derive the PCB as surfaces you mean just redo the part as a surface? Is there a way to automate this if I already have the PCB as a part?
thanks
Alan
Sorry just realized I have two accounts, guess I forgot about one of them. In case the reply above disappears here it is from my regular account:
thanks
Alan
Never mind, I see what youre saying, just saw the derive button. I'll definetly try to do it that way next time. Thanks!
Also just found out about SHIFT+RightClick for selection preferences, that might also help.
thanks
Alan
I just re-made my part using your method and I have to say it helped A LOT. Thanks for all the help 🙂
What is the point of the 3D modelling tab in the assembly if you can not modify the underlying parts?
The 3D modeling tab (tools) work exactly like the real world.
Features added after the parts are assembled (like match-machined holes).
If you want to modify the underlying parts in the context of the assembly - simply right click on the part and select Edit Part.
Now instead of assembly feature tools, you have the part feature editing tools.
