Inventor Forum
Edit / delete material in library Inventor 2013
1 REPLY 1
685 Views, 1 Reply
how to edit or delete existing material in the library?
In a part, I can rename, delete and create new materials using the Material broser.
But how to transfer this modifications to library?
The only way i see is to "save styles to style library", but with this feature only the NEW created materials get saved in the library. But how to delete or modifiy materials that are already in the library?
Thanks in advance
Markus
1 REPLY 1
CCarreiras
Hi!
You can't edit or delete the material database, instead, make a copy of a existing one and edit the new material name and properties. You can delete the custom materials, not the standard (it's suppose the database materials to have the proper properties).
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
