Inventor Forum
Edit Model Dimensions in .idw
3 REPLIES 3
426 Views, 3 Replies
According to Help...
"If you set the option to edit model dimensions from a drawing when you
installed Autodesk Inventor, you can change the model dimensions in the
drawing."
Apparently this option was not selected during my install, because I cannot
double-click the dimension to edit it. I'm not trying to override the text,
I'm trying to change a part's geometry. Is there a way to toggle this
setting, or must 5.3 be reinstalled?
3 REPLIES 3
Did you use model dimensions when you made the drawing view?
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Alex Alexander" wrote in message
news:8B9E2A7ED12D5C3BB192584EE8DCE530@in.WebX.maYIadrTaRb...
> drawing."
Yes. I've checked "Get model dimensions on view placement" in Application
Options/Drawing, then created a view in a drawing. But double-clicking a
model dim merely brings up the Dimension Tolerance dialog.
"Kent Keller" wrote in message
news:FEEF6E07997031D1680001F640D09F1B@in.WebX.maYIadrTaRb...
> Kent Keller
> > drawing."
I've got it. RMB the highlighted model dimension, then select Edit Model
Dimension.
news:189B5C7951F89496FF955CD3903C2E6D@in.WebX.maYIadrTaRb...
> > Kent Keller
message
you
the
> > > drawing."
